- Joined
- 27 Jan 2008
- Messages
- 27,482
- Reaction score
- 3,323
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have two programs that should work with this radio, however the 'CHIRP' program will not set the language, it will set frequencies, wide/narrow, and all needed to use the radios, but it now talks in Chinese, it did talk in English before I replaced the illegal frequencies for those I am permitted to use.
The HKT-480 Radio Program Software 888S will read what is on the radio, but does not seem to write to radio, it did the first time I tried, and the radio on switch on just emitted a tone, which is why I tried programming with 'CHIRP' once done in 'CHIRP' I could read the programming with HKT-480 Radio Program Software 888S and alter things, and it reported it was writing to radio, however when I read it again I find no change, still talks Chinese, the channel numbers are very small and all I can do is go to channel 1 then count to channel I want.
I will be getting a UV-B6 for Christmas so hoping it will not have the same problem!
