I have an external side door which is never used, and will likely eventually be bricked up, but I want to secure it for now, with some kind of drop in barricade.
The door is in a corner with brick walls at both sides (the hinges are in the corner).
I had planned to barricade it with timber, but because it is in a corner any bracket that side would have to be flush with the wall.
Plan B is to use box section, with holes drilled into the wall at the corner, and then brackets, on the other side.
I was hoping that I could use 25mm x 25mm x 3mm mild steel.
Will this work? Is there a better way?
