Hi All,
I have a Bosch SGS5358GB/17 dishwasher, overnight the pump jammed and it tripped the circuit breaker. On inspection this morning there was still water in the bottom of the machine but the dishes were clean. I reset the circuit breaker and emptied the water and checked the pump, which had two tablets in it probably paracetamol (could be why the wife still has a headache).
Anyway pressed the start button and nothing, changed the fuse, and tried again, still nothing, pressed A and C together to reset and the panel flashed with what looked like reversed LL, on subsequently pressing the timer button i get II, the 70 degree gives --, the 65 degree gives 11 and the 35 degree gives _ _ the other two button give nothing.
I feel the panel may need to be reset, or is there some other solution.
Best regards, Tony.
Best regards, Tony.
