Hi Guys,
Just removed a chimney breast from the loft downwards on the front side of the house. Well, just removed the 2nd floor for now, downstairs will follow. Used gallows brackets with resin set bolts and pre stressed concrete lintel. Messy, but good fun..
Q, what is likely to support the concrete that forms the area in front of the fireplace. This is the area that forms a rectangle about 30cm in front of the breast and I guess acts as a solid base for burnign embers and heat. I will want to remove it, but just curious how this is likely to be supported in the floor joists?
