Hi, we're in the process of purchasing a property where the ground level is at 1st floor at the front, and basement level at the back (so 2 levels).
We want to convert the basement to a liveable area, but two of the rooms, on the left side of the house, have damp issues to the exterior walls.
There is no access to the walls from the outside, as they are below ground (one completely, the other partially as it's at the back of the house).
A builder friend has advised first laying concrete down on the ground level around the property as currently it is slabbed and letting rain water through into the ground, and then sealing the interior walls in the basement with membrane.
My questions are:
1) Will this damp be affecting the structural stability of the house?
2) Is this the most effective way of damp proofing the basement? If not, what is?
3) Will that method maintain the structural stability of the house? I ask because surely the walls are still getting wet if the membrane goes in the inside?
4) What is this likely to cost? The walls are 11' and 14' wide, along the left side of the property.
Any help and advice would be massively appreciated.
Thank you in advance.
My questions are:
