OK, time for me to learn some basic plumbing skills in a hurry. I’m fitting a new toilet, and here’s a pic of the existing water pipe. It will be close to the inlet on the new cistern, but alas, not close enough – it’s both a little short, and slightly off to one side.
So I’ll have to cut it, I guess, make some sort of joint, and extend it. The existing isolator tap works fine, so could be retained, but no big deal to replace it with one of the little ones, I guess, if it was desirable to cut the pipe below that (except then I’d have to drain the big water tank in the attic etc).
Thing is, I know there are compression joints, push-fit joints, copper pipes, and plastic pipes, and I haven't a clue what sort of configuration to use – could somebody advise me what to do, and what bits I need to buy, in really simple terms please?
Thanks guys
Thanks guys
