Hello to all. Just a quick question. I have replaced an old window with a new UPVC unit. I now need to fix some quadrant trim to the sides and top of frame outside to hide the gap between frame and brickwork.
I have some plumbers solvent weld, the stuff you use to join plastic waste pipes. Is this the correct stuff to stick the quadrant to the upvc frames? Or do I need another adhesive?
Thanks for any advice.
