Just a quick technical question.
In the downstairs loo the basin waste runs out through the external wall in 32mm solvent weld pipe and into a boss as seen here:
Looks ugly as hell outside the front door so if possible I would like to attach into the toilet waste internally.
Currently the toilet outlet looks like this:
I was wondering if I could remove the toilet coupling and add something like:
with a blanking bung in the top hole and connect the toilet and basin waste to it.
I'm guessing I can't do this as flushing the loo would trash the seal in the basin waste, is there any way around that or is it not likely to happen? The basin is around 2.2m away in pipe length from the current toilet outlet if that makes any difference.
