Two separate questions really, I'm not sure if they should be in here or the building forum!
Got a guy in fitting my new bathroom at the end of the week, he is fitting an 1800 x 800 bath which has a max capacity of 150 litres. So circa 170kg for a full bath and no people..
The original 1700 x 700 bath was placed across the joists but the new plan that the "designer" did has the new bath rotated through 90deg placed in the same direction as the joists...
This has me slightly worried as the load isn't spread over so many joists... Should they have consulted a structural guy? Or is it perfectly ok as is?
The other thing was that the entry onto the soil stack needed rotating as the toilet is supposed to be fitted against another wall in the new plan. When it was all ripped out at the end of last week he just pulled the pan waste pipe round and the whole stack above it twisted with it!
Above the bathroom the stack goes through the loft then it goes out side through the roof. Won't this have broken any water tight seal where it meets the roof? Or does it just sit inside a special kinda roof tile?
