Bath rail (wall mounted) - is there a particular type to go for or avoid?
11 Sep 2007
I'm just thinking of a short-ish, 30cm rail to fit to the tiled wall that the bath butts up against. Are there any makes to avoid or go for?
If you are talking about a hand pull rail then not really, they all have to meet a certain standard so just make sure it is properly certified.
The key with them is fitting, if it's a brick wall then nice M10 anchors, if it's framed then nothing less than fixed directly into the uprights, making sure the uprights are properly secured. If they're not and there's any movement at all then don't fit without remedial work to the wall, otherwise there's a risk of a major injury just waiting to happen.
Thanks, makes you wonder what the difference is between that one on amazon and the following more expensive one:
