bath shower mixer problem
8 Apr 2006
Hi everyone-first post,I have a problem with bath mixer tap with shower attatchment. its a newly fitted one and we have very high cold water pressure and the hot is gravity via cistern and vented cylinder. When we try to use shower mixer we put hot tap on but as soon as we open cold at all it seems to stop the hot completely. Is this because of the high water pressure and if so what can I do about it? pressure reducing valve? Any help and advice appreciated-thanks Les
Supplies should both be at the same pressure, which yours aren't. You can try a pressure reducing valve on the cold, or a pressure equalising valve, but you're asking a lot of it so it won't be perfect.
ChrisR said:
Supplies should both be at the same pressure, which yours aren't. You can try a pressure reducing valve on the cold, £15.00 + VAT from PTS :wink: asking a lot of it so it won't be perfect.
