    Dismiss Notice
Bathroom boarding
Discussion in 'Plastering and Rendering' started by marsaday, 13 Feb 2011.
  1. marsaday
    marsaday
    1 Nov 2007
    1,269
    Thanks Received:
    8
    Yorkshire
    Country:
    Do you need to use moisture resistant boarding in the bathroom ?
    I will be using the cement type board behind the shower, but didnt think it was crucial to have the MR board in the bathroom?
    I havent done it yet and so could get some in, but i do have a load of normal board to use up.
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Not crucial to use MR boards they do help in wet/damp environments, but I have used the standard boards in many bathrooms and had no problems, if you board out your wet areas with aqua/cement panels should be fine.
  4. darrington
    darrington
    28 Dec 2010
    444
    Thanks Received:
    103
    Country:
    Id go along with that. The tiled wet areas are always the most crucial.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
