Hi, me again. After I fitted the in line fan over a year ago I have a problem with the ceiling around the vent above the shower getting damp and going black.
I want to replace my in line now with a safe none in line extractor, could you recommend me one please?
I doubt that being in-line is your problem.
Looking back, I see there are some unanswered questions ... Is your duct lagged ? Is is sealed properly to the intake grill ? Is there a back-draught shutter ? Does the fan have a run-on timer ?
If the duct is unlagged, then it will cool from the cooler air in the loft. There will be condensation on the inside of the duct, and that can run back down and if the duct isn't sealed to the grill, then it could seep between duct and grill spigot - thus wetting the ceiling plasterboard. Not having a run-on timer will make that worse. Also, when not running, air in the duct will cool, and circulate downwards to create a cold spot in the ceiling - thus promoting your damp problem.
So well lagged duct, sealed so that condensation can't leak to the ceiling, a reasonably long run-on time (to clear the damp air after a shower), and a back-draught damper (to stop cold air flowing back) will all help. BTW - there are traps you can put in vertical ducts to catch condensation and prevent it running back down and dripping from the grill.
Also, a flow switch in the supply to the shower would work to prevent people not using the fan by leaving the light off - as SWMBO would be prone to doing. It is "a difficult task" persuading her that the answer to black patches in the ceiling corners is to get the damp out as quickly as possible - rather than nuking it periodically with bleach
