Bathroom extractor fans - standard or low voltage?
25 Apr 2009
Somerset
Hi All,
I'm replacing the existing (240v) ceiling fan in my bathroom. I want a humidistat-controlled one and have bought this one for £30. However, I went into B&Q and they're currently doing a low voltage fan which is only 30dB and £6! Is there a catch I'm missing? Should you avoid low voltage fans unless you're putting them in a shower cubical? Obviously I'd need to buy a transformer as well (which would go in the attic) - I was thinking of this one.
Any help/opinions appreciated :)
Adam
How about the obvious one that there's probably a good reason why the B&Q one is 80% cheaper than the Screwfix one?
Not that I know of. (BTW - http://www.diynot.com/wiki/electrics:voltage-bands)
Thought you wanted a humidistat operated one?
Heh. Well, if I always bought expensive things just because they're expensive I'd be a much poorer man! ;)
Not that I know of. (BTW - http://www.diynot.com/wiki/electrics:voltage-bands)[/QUOTE]
Interesting, thanks for that.
Yes. I was just going to leave the transformer on and let the fan turn on and off itself. Is that a mistake?
Thanks,
Adam
They don't work like that. With ELV fans the timer or humidistat function is in the transformer.
From what I saw in B&Q, this cheap fan did not come with a transformer, but said it had a humidistat. That doesn't sound right given what you've just said. Maybe I was mistaken - I'll have another look in B&Q at the weekend.
Thanks,
Adam
