Bathroom fan exiting through vertical tile hanging.
23 May 2006
Southampton
How do you get the 100mm dia vent past the external vertical tile hanging and make weather tight?
They are normal small roof tiles.
Just treat it like a pipe passing through a normal pitched roof (albeit with a very steep pitch!) and fit a weathering slate over the pipe.
Thanks TT
Couldn't get access to outside of vertical tile hanging, so cut a hole in plasterboard ceiling and threaded flexi hose to outside soffit board. Lucky all ceilng joists going the right way for a change. Hung out small window and cut hole in external soffit, fixed vent grille.
I've being meaning to get that sorted for a long time, but the tile hanging was/is so fragile, to frightened to give it a go.
