Bathroom Project
17 Apr 2021
We are planning on partitioning off part of our existing kitchen and turning it into a shower/toilet/laundry room. The only problem we have is this room wont have any external rooms or windows , it does sit right next to the soil pipe stack and directly below our bathroom on the upper floor of the house.
My problem is how can i ventilate this room for the purpose of the shower ? Can i go up through the existing soil stack ? perhaps duct around the room and through the existing kitchen behind the cupboards , is there a height level the duct needs to be at ?
Sorry for so many questions but i am hoping for some advice on at least some or all
thanks in advance
The ducting for the ceiling fan will run in the ceiling void to an external wall.
even in a downstair toilet ? im not sure how they would access the ceiling through the two rooms required to reach the outside wall
You can either take the floor up in the room above to get access or take part of the ceiling down in the shower room and kitchen
Access could be by lifting the flooring upstairs or dropping the ceiling downstairs. Direction would be dictated by orientation of the joists.
can the vent not be run through ducting and boxed off along the existing walls ? taking the ceiling or floor down sounds like a nightmare scenario
Surface run boxed ducting is a cosmetic nightmare. Still it is your property.
totally agree . im just trying to think of practical solutions that wont involve it turning into a major project , i thought perhaps the ducting could run behind kitchen cabinets as thats the next room to be done so they wont be seen. Does the room only need a vent because of the shower ? if i just made it a toilet/laundry room would that require ventilation ?
You need to check the Building Regulations with you local council as this work is possibly notifiable. I would have thought any toilet would require ventilation. Going back to the ducting a competent builder may be able to "fish" a flexible tube through the void after cutting the exit hole in the external wall.
:mrgreen:
