Bathroom refit
15 Sep 2023
Hi all
I'm refitting my bathroom, All will be replaced in situ and same place apart from the bath has a shower mixer tap and i'm planning on replacing this with a bath hot/cold water supply and a thermostatic shower above with its own supply.
Cold is mains fed and hot water is a closed system with expansion vessel. Cold feed is 15mm and hot is 22mm I think is 22mm is left over from when the system was changed from a tank system.
Few questions....
1 Can i split the current supply to the bath mixer and use it for the new shower and bath feed? See my (poor) image below
Second question is the "tap end" is currently just boxed out to hide the soil vent pip. Assuming no issues added a shower and the pipe work to this?
Also the feed to the hot bath tap isn't that great pressure wise if other hot tap is on. Is the solution a shower pump to boost pressure?
Yes ,you can tee into the existing bath supplies for shower.
How do you intend to get the pipe work into the false wall ( boxed in part) ,are you planning to re tile ?
If your hot water is from an unvented cylinder ,under mains pressure, you should have good pressure hot water ??
Thanks for the reply.
Yes the false wall will be taken down, pipework all added then wall replaced and whole bathroom retiled.
I did think it should be good pressure as well. I'll have a look at the system
