Hi All,
I've been lurking on these forums for a while and finally decided to register!
I'm about to refurb my bathroom which was done badly just before we moved in - hence re-doing it unfortunately.
My question is:
Do the walls look okay to tile directly onto, once I have removed the existing tiles, or do I need backer board?. I would need to strip right back to the brick probably then fit it.
Here are images of where the bath sits: https://ibb.co/hEpJAa and https://ibb.co/hMmyAa
You can see the fitter had to use a lot of adhesive in this image, since you can see how deep the tiles are at the edge (which I don't want to replicate): https://image.ibb.co/mxyBVa/UNADJUSTEDNONRAW_thumb_1806.jpg
Background:
Problems with existing bathroom, prompting this work:
https://image.ibb.co/gndpGF/UNADJUSTEDNONRAW_thumb_43e.jpg
https://image.ibb.co/bGopGF/UNADJUSTEDNONRAW_thumb_411.jpg
https://image.ibb.co/mgcibF/UNADJUSTEDNONRAW_thumb_422.jpg
https://image.ibb.co/h5L3bF/UNADJUSTEDNONRAW_thumb_423.jpg
https://image.ibb.co/mMj73v/UNADJUSTEDNONRAW_thumb_424.jpg
https://image.ibb.co/daeJAa/UNADJUSTEDNONRAW_thumb_17ff.jpg
My question is:
Background:
- The sides on the bath are currently tiled, and the sides are not flush with the bath
- To fit plastic sides on bath I need to pull the it out of the wall slightly (and it's been tiled in).
- The tiles need to go to the ceiling due to high-moisture, small bathroom.
- The floor is tiled and needs to be removed in order to fit the bath sides (and the floor has been done badly anyway - holes cut in wrong place etc).
