- Joined
- 27 Jan 2008
- Messages
- 28,693
- Reaction score
- 3,500
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
In the past my battery chargers did have some current regulation, but in the main it was voltage, so on switch on the charger would bang out 35 amp, until the volts hit 14.8 volt when it would hold at that voltage until the current dropped to 3.5 amp at which point the volts dropped to 13.4 volts and it would be held at that voltage. There was also a timer so if it did not drop to 3.5 volt it would still reduce voltage after a set time, and there were some options with some types of lead acid you could select 14.4 volt instead of 14.8 volt.
So other that the start the output was voltage controlled.
However I have bought a stage charger where the current is regulated not the voltage.
Stage 1 it tests polarity.
Stage 2 0.8 amp pulse between 7.5 and 10.5 volt.
Stage 3 3.8 amp until voltage reaches 12.8 volt.
Stage 4 3 amp until voltage reaches 14.1 volt.
Stage 5 0.8 amp until voltage reaches 14.4 volt
Stage 6 0.1 amp until voltage drops to 12.6 volt
Stage 7 0.8 amp until voltage reaches 14.4 volt
So in real terms 4 stages starts at 3.8 amp then drops to 3 amp, then at what it considered as 80% charge drops to 0.8 amp and once fully charged maintains at 0.1 amp it will however cycle between stage 6 and 7 if the battery voltage drops.
I have tried recharging two completely discharged batteries, one very old 88 Ah and one nearly new 75 Ah in both cases I had to use another charger to get voltage over 7.5 volt and in both cases that resulted in missing the pulse stage, the 88 Ah was that sulphated that it dropped to the 3 amp stage nearly straight away, when the charging was interrupted and restarted it did spend one hour at 3.8 volt, it took 15 hours to reach the 80% charged stage, it never reached the fully charged stage even after 2 weeks on charge.
It was used to replace the 75 Ah in the caravan which was also found fully discharged and it worked the motor mover to get the caravan out so clearly the battery had been charged. Which I did not expect since it had been left for a year without charging.
The 75 Ah was far faster it was a new battery 2 months ago, the chart is from energy meter so first peak 12.30 to 1:30 is the other charger getting the voltage high enough for the charger to start working, the dip 2 Nov is where it dropped from 3.8 amp to 3 amp, and between 6 and 12 it dropped to 0.8 amp and 3 Nov dropped to 0.1 amp, not really nice curves energy meter software has done that.
However it did take from Wednesday to Friday to recharge the battery, however it does actually tell me when fully charged it's not look at ammeter and guess.
Clearly a very low charge rate, the whole idea of the old stage charger was to recharge batteries within a 8 hour shift patten so the fork lift or milk float was ready for next shift. The one I used was on a narrow boat so it needed to recharge batteries as quick as possible when we got a shore supply.
But question is do these really low output chargers actually look after the batteries better? Mine is a really cheap one from Lidi but some are rather expensive the Ctek seems to be the well know make.
Because current regulated and the voltage determines the stages not sure how high the first stage could go to, Ctek also do a 5 amp and 7 amp version and even one with 60 amp but as to how these work I don't know?
But it seems today we have a whole range of lead acid battery chargers using methods never considered when I trained as an auto electrician back in the 1970's I did worry a bit when it held the 88 Ah battery at 14.2 volts for such a long time, never quite reaching the 14.4 volt needed to drop it into final stage.
I would like to hear what other have to say about this new bred of lead acid battery chargers.
