- Joined
- 27 Jan 2008
- Messages
- 27,547
- Reaction score
- 3,329
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a cheap radio (JingTong JT-208), however worked well for a good few years, until last year it would only receive, pushing PTT it would turn off and on again as the battery voltage dropped.
So hunted for replacement battery on internet, but non found, except USA it said on battery case NiCad and the charger was very cheap I would feel radio and once battery hot would assume charged, there was no cut off once recharged.
So decided to break the casing apart and see if I could replace the cells, once exposed rather surprised to see marked AAA NiMh and internet hunt and it seems I can buy a pack of 6 ready connected together designed for toys around £8.10 with postage and 700 mAh instead of 600 mAh. Some up to 2000 mAh from RS but price jumps to £22.
This
would be best format, no need to solder each cell, what ever needs to be with solder tags.
However the question is the charger,
paying out £6 for a battery OK if it's wrecked not really a problem, but with more expensive versions it is more of a problem. Remember whole radio was around £30 new, with an new duel band version now down to £24 maybe best place is the bin?
However goes against the grain to dump a good radio just because battery has failed.
What I need is a local model shop I suppose where I can pick up batteries and be sure they will fit in case, Wrexham area.
This
