Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hello, could I know if anyone knows that could I power the 5VDC LED Tape with 3PCS 1.5V Batteries, I will install the batteries in a battery holder box, the total output voltage only 4.5V, can I?
Maybe it will work fine at 4.5V?
4x 1.2V rechargeables would get you 4.8V which is surely close enough.
3x 1.6V lithiums would also do the same.
On the other hand, I would have thought that your use-case is common enough that there already exists a product to do this.
You could consider a USB power bank - a 5V supply, with some large capacities available, with built-in charging and all supplied in a convenient enclosure!
...although, be aware, the longer the LED tape, the shorter the battery life!
