Hi all,
Hope you will be able to point me into the right direction.
My boiler stopped working on Thursday after two days of central heating use.
Now is giving me fan/flute error code. Got gasman today, who replaced air pressure switch (not much difference) then PCB (no difference), he checked Fan (works fine) and tubes that goes to the switch. He was able to start ignition by blowing air into the switch but the boiler won't go pass fan fault. Baxi infoline recommended replacing Venturi (which looked fine to the gasman and was cleaned by him). Any ideas what else can be wrong.
The gasman is back on Monday but I don't think I should be playing for PCB if the new one makes no difference.
Thank you,
MaxNoGas
Thank you,
MaxNoGas
