Hi everyone,
I have just replaced the pressure switch on my boiler and it works.
only thing is when i removed the front cover, there is a metal plate to remove with BAXI on the front and a small window,on the inside of this plate there is a black seal that goes around the outside, obviously to seal the plate, this is damaged and seems that it wasn't fitted correctly in the first place.
I have looked all over for a replacement and asked the guy at the shop from where i got my pressure switch about it and he did not have a clue as i couldn't find a part number, i even showed pictures of it and he still wasn't sure.
Does anyone know where i can get a replacement for it,
if anyone is not sure what i'm on about, i'll upload the picture from my phone,
also when i have fitted the pressure switch is there anything i need to do afterwards? or is just simply a swap?? i made a small diagram of which wires goes where and the tubes and checked that the tubes where not kinked when fitted.
thanks
michael
thanks
michael
