Baxi 105e Combi. leak from Diverter Assembly
26 Mar 2009
Following previous leak, fitted new Diverter Valve Assembly and fine for just over a week, now a leak again from the same place, where the grub screws secure the DHW Pressure Differential Valve to it.
Have read a lot of similar items on this site but none where a new one has been fitted. Help would be greatly appreciated.
Thank you in advance
Mollllyrockers
Did you just change diverter valve and not the diff press unit?
If so its proberbly a leak at the back of diff pressure unit
Thanks, bought and fitted diaphram kit /mini seal. Upon restarting I'm getting the pump kicking in but the flame not starting or then it starts and then knocks off again but the pump continues, ie cold water. No fault leds are flashing. I presume it's something to do with the sensors but can't get my head round it. HELP appreciated.
Thank you.
Mollyrockers
