baxi 105e combi
5 May 2009
Kent
hi all
i have a problem which is i have no h/w or c/h after a while the fan neon flashes up red i go to the fault section and it suggests the air pressure switch needs replacing can anyone confirm if this is correct
thanks all
Does the fan run?? If so it may well be the aps, or it might be a blocked venturi, kinked pipes etc. If the fan doesn't run then its the pcb or fan itself. I would suggest at that point you call an rgi
the fan dont run we took it out and put 240v across it and it worked
check the air pressure switch either with a mutlimeter or by shorting it out. if this is okay the chances are it is pcb.
Powell30 is giving you all the correct information. It probably is aps stuck in normally open by sounds of it. However if your not competent you really shouldn't be undertaking work (as defined by gas safety regs) on your appliance.
Get an RGI in.
...However if your not competent you really shouldn't be undertaking work (as defined by gas safety regs) on your appliance.
Get an RGI in.
Which is why the majority of RGI's on this forum do not give information about working of flues, fans, aps, and other safety critical items.
think that was the point I was making and why I withheld information on testing of these items
Indeed. It never fails to amaze me when I read what people do, how much time and money they spend on changing the wrong parts, and often the problem is solved by a pro for under £100 including a service.
hi all
i think i got it wrong there is not enough power getting to the fan to activate it when wiring the fan up to test it works fine the book suggests a pcb board is that right
actually my mate a plumber and registered sorted the problem out so he should get the credit but thanks to all who had their say
