Hi again.
My combi is still dripping when you use the hot water. I've changed the diaphragm in the hot water differential valve and the little o ring on the push rod but that didn't make any difference.
I stripped it down again and noticed that the water is coming pass the tip of the pushrod that is left facing you when you've removed the DHW differential valve. ie the pushrod that's in the diverter manifold.
Is it worth changing the central heating diaphragm that screws on top of the diverter manifold? Can the the diverter be dismantled to get to that little pushrod thing!?
Any help much appreciated
Cheers Zeb.
Cheers Zeb.
