Hi guys
My problem started about two weeks ago I have had the baxi 105e for about 5 years and up until now sounds like I have been lucky not to have had any problems by reading some of the posts, anyways ,The hot water has decided not to work , well let me explain.
When I turn on the water nothing happens it does not run through hot now from checking the the boiler I can tell you the hot water led does not light nor does the boiler sound like it is kicking in but here is where it gets interesting.if I turn the tap of and then back on full the hot water kicks in and all is well the next i try to use it will do the same thing sometimes it takes about 3-4 times of turning it off and then back on to get it to kick in so to speak ,anyone got any ideas ,
quickly something I forgot to mention is that no matter how many times I turn it off and then back on if I dont have the hot tap on full it will not get hot at all ,so to simplify i can turn the hot tap on a quarter turn and run it all week and it will still be cold but turn it off and then back on full and it works fine
thanks
thanks
