    Dismiss Notice
Baxi 105e Instant Combi boiler no hot water.
Discussion in 'Plumbing and Central Heating' started by DrGonzo98, 19 Feb 2018.
  1. DrGonzo98
    DrGonzo98
    2 Sep 2009
    8
    Thanks Received:
    West Midlands
    Country:
    We have a Baxi 105e instant combo boiler that’s suddenly stopped producing hot water. Central heating is fine but the boiler doesn’t fire up when you turn a tap on.
    If I turn the pre heat on full the boiler does fire up (hot water light flashes constantly), however I only get a small amount of hot water.
    Baxi have quoted £340 to fix.
    Could this be a diaphragm or is it something more expensive?
  2. rochdalegas
    rochdalegas
    21 Feb 2012
    91
    Thanks Received:
    19
    Lancashire
    Country:
    Quite likely to be just the diaphragm. Whip front cover off. Turm on hot tap you should be able to see the pin come out on divertor and make the switch
    • Thanks Thanks x 2
  3. Sponsored Links
  4. DrGonzo98
    DrGonzo98
    2 Sep 2009
    8
    Thanks Received:
    West Midlands
    Country:
    Do you know which Diaphragm I need part number wise?
  5. rochdalegas
    rochdalegas
    21 Feb 2012
    91
    Thanks Received:
    19
    Lancashire
    Country:
  6. Sponsored Links
  7. DP
    DP
    10 Dec 2003
    15,148
    Thanks Received:
    3,355
    Glasgow
    Country:
    A service might be a good idea. Service as per the boiler manual
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
