Hi all!
I have been experiencing hot water porblems with my combi boiler.
The central heating is working properly but the hot water isnt working at all.
I have de-assembled the pin assembly from the micro switch (sensor) through the diaphram and into the brass joint thing behind the diaphram.
The pins were sticking but i greased them and now they all move freely.
By pulling out the pin that enters the micro swithch knocks on the boiler and the hot water heat up. After the hot water tap is switched off the pin retracts and the system shuts down.
So to sum it up!
The hot water doesnt work until the pin is pulled out manually and after the hot water tap is turned off the pin retracts and the system shuts down.
The pins all move freely. The diaphram has been replaced. The micro switches have both been replaced and the black box that sits on one of the brass heads to the left has also been changed.
i've had a corgi plummer attempting to fix it but he left without finding the problem.
Any ideas????
aquaranger
So to sum it up!
Any ideas????
aquaranger
