Baxi 105e hw but no ch
22 Nov 2005
Yorkshire
my baxi 105e works fine for hot water, but when I try to put the central heating on it fires up for a few seconds then the flame goes out, it does this a few times before stopping. The flame failure light (30) then flashes.
The plumber thinks it is a problem with the pcb and tried replacing it, but this didn't work and he thinks the new pcb is faulty and has ordered a new one
Similar problems in the forum suggest a problem with the diverter valve or the diaphram. is this more likely than the pcb? (the plumber's a good guy but he's more of an installer than a repairman)
Steve.
The diverter valve is easily checked visually ( by someone who knows what to look for!" ).
It seem to me that your boiler may think its delivering hot water.
It could be a PCB fault but I would first suggest that the gas valve maximum and minimum settings are checked by a CORGI engineer and then any settings on the PCB.
Boiler repairs are easy but only for those who understand how they work!
Tony Glazier
Your problem lies with the gas valve. I would suggest that the min gas setting is incorrect, it is not likely to be a wet problem as the boiler is failing on flame sensing. Setting the gas valve up is for a corgi installer ONLY.
