Hi. Just moved into a house with a Baxi 105e boiler controlled by a Honeywell hcw80 thermostat. The heating was ok until the house got rewired but since then the c/h will not come on. The hot water works ok and the pressure is just over 1 bar. I have reconnected the two honeywell devices and they do appear to be communicating. However when i move the dial for the stat the heating does not kick in. When i turn the dial to 25 degrees a red light comes on and goes off after a few seconds. Does this sound like a stat problem or a rewire problem? Thanks in advance!
