baxi 105e pressure
4 Nov 2009
Dorset
Im still battling with pressure issues...each time i top it up it works for a few hours - but on other times - like last night - it lasted 14 hours with no top up...
why would it go for longer periods on some occasions than others ?
i have seen many posts here about the same issue - with losing pressure - is it somemthing that you can replace yourself if its a standard part ?
You have a leak or your expansion vessel needs recharching or replacing. No you won't be able to replace it yourself but you could fit an external one on the return pipe if you feel able.
Try recharching your exp vessel first tho. Do a search on here to see how
