loosing pressure in baxi combi 105e bolier
8 Sep 2013
Lancashire
Hi, hope someone can help, i changed the diaphragm in my baxi combi 105e boier yesterday as pin wasnt meeting microswitch , its working great now but the pressure is dropping continuosly and im topping up pressure approx every couple of hours, but i cant find any leak can anyone help
Have you checked that the pipe going outside (pressure relief) is not dripping?. It may also be that your expansion vessel requires recharging.
Did you drain/ de-pressurise the system prior to changing diaphragm?
i de-pressurised the system (bled radiators) i cant tell if pipe is dripping outside as its lashing rain outside now, but i dont remember seeing wet on the ground earlier
Either you have a leak or the pressure relief valve is passing. That's the only way water can escape your system. Re-presurise the system and tie a plastic bag over end of pipe outside and see if it stays dry.
