As per the title - have had persistent issue with hot water running hot for about 20 seconds, then running cold, then running hot again. Central heating has also been doing the same. Radiators would also heat up when running the hot water.
I have drained the system and replaced plate heat exchanger and wet pocket thermostat to deal with the former, and the diverter (it was in a sorry state) with a Baxi original to deal with the latter. Have also ran some cleaner through before draining, and the MagnaClean is picking up very limited junk. Expecting all to now be well I repressurised, bled radiators, then repressurised. Rinse/repeat a few times until the air was gone and set final pressure just above 1 bar.
However now the air has been removed from the radiators, the boiler will not light and I get an error on the pump / low pressure light. Neither central heating nor hot water will work.
I've had the screw from the pump head off and the pump can turn freely, and I can hear it running albeit much more quietly than before. The diverter is activating the microswitches as expected.
Any suggestions on the cause?
