    Dismiss Notice
Baxi 105e still losing pressure after pressure release valve replaced
Discussion in 'Plumbing and Central Heating' started by Adam75, 5 Oct 2021.
  1. Adam75
    Adam75
    1 Feb 2007
    100
    Thanks Received:
    Ipswich
    Country:
    Our boiler was losing pressure with water coming out of the pressure release valve pipe. I’ve replaced the pressure release valve but water is still coming out.
    With the heating on the pressure is 2.5 bar, water is clearly more than dripping out of the pipe.
    Is there something that needs to be reset when replacing the valve?
    Adam
  2. Sponsored Links
  3. denso13
    denso13
    22 Jan 2007
    5,634
    Thanks Received:
    1,117
    Country:
    Probably the charge in the pressure vessel, nothing to do with the PRV.
    • Like Like x 1
  4. Adam75
    Adam75
    1 Feb 2007
    100
    Thanks Received:
    Ipswich
    Country:
    Thanks Denso13. Does this mean the pressure vessel pressure is too high or low? I’ll check to see if it’s around 1 bar
  5. CBW
    CBW
    26 Sep 2019
    9,007
    Thanks Received:
    2,400
    North
    Country:
    Too low or none existent (frequently).
    • Like Like x 2
  6. kidgreen61
    kidgreen61
    8 Mar 2009
    2,415
    Thanks Received:
    575
    Staffordshire
    Country:
    It should be precharged to around 1 Bar, this must be done with either PRV open, or a drain open so that it's not trying to pressurise the heating side of the system.
    • Thanks Thanks x 1
    • Like Like x 1
  7. Sponsored Links
  8. Adam75
    Adam75
    1 Feb 2007
    100
    Thanks Received:
    Ipswich
    Country:
    3 weeks ago I drain the boiler and re-pressurised to 1 bar. This evening the boiler started to make banging noises when in the shower. The water went hot cold hot etc.
    The banging noises sound a bit like flapping, like a bad flat tire. I’m wondering whether the expansion vessel has popped.
    I re-drained the boiler and checked the pressure, still at 1 bar. Reduced this to 0.5 as the manual suggests. Still the same issue.
    the banging/flapping starts about 30 seconds in. Please see the attached video.
    Does the expansion vessel need replacing?
  9. Registered Gas Man
    Registered Gas Man
    9 Nov 2003
    378
    Thanks Received:
    44
    Birmingham
    Country:
    Like you I like to try to sort things myself and I'm often successful. Part of having that skill is knowing when to get a pro in.
    It's time!
    • Thanks Thanks x 1
    • Like Like x 1
  10. DP
    DP
    10 Dec 2003
    14,821
    Thanks Received:
    3,256
    Glasgow
    Country:
    Adam, leave the boiler alone else you will damage it
    That banging noise is lack of circulation, water is turning to steam hence banging.
  11. Adam75
    Adam75
    1 Feb 2007
    100
    Thanks Received:
    Ipswich
    Country:
    I agree it’s definitely time for a plumber. Just wanted guidance of what it might be so I have the confidence the plumber knows what he is doing.
    is it ok to use while I wait for a plumber?
Loading...
Share This Page
