Hi all,
Wondering if someone can help...
DHW on my ageing baxi 105e (not HE) is cycling.
Gets nice and hot, then after a few minutes the temp lights go out, the 70 degree fault light flashes once indicating a DHW temperature fault, the pump and burner (if it's lit at that particular time) stop momentarily and then everything restarts as per normal. However this causes a drop in DHW temp whilst everything gets back up and running which is annoying if you're in the shower. (Mixer type not thermostatic shower)
The pump sensing pin drops momentarily which confirms the pump shuts down.
CH appears fine.
My first port of call was going to be the DHW thermistor followed by the plate heat exchanger.
I don't want to disturb the plate heat exchanger during winter whilst ch is working ok as if I can't re-seal it that would be a problem.
Any ideas? Am I barking up the wrong tree?
I'm in the NW so water is soft with no limescale by the way.
Thanks folks
CH appears fine.
Thanks folks
