- Joined
- 18 Oct 2004
- Messages
- 11
- Reaction score
- 0
- Country
Quick query, had a Baxi 105HE installed November '05, and it has run very well and performed perfectly adequately.
However, in the last few days the hot water from the taps is not as hot as it was. Used to be able to get really hot water (at times the water almost looked white as it came out the tap) but in the last few days the water seems be around 'very warm' to the lower end of hot.
There is definitely a noticeable difference and while it is manageable at the moment I am wondering if this is a simple maintenance issue, or the portent of worse things to come and a degenerative fault
There are no outward signs of fault, all the lights which should come on do, have the Taps temperature setting to max and Rads to about the 6 o'clock position, and the C/H and rads work as well as ever.
No apparent leaks, flue working OK and pressure at about 2 bar when running. We are in a hard water area. There is a Thermostatic shower working off it upstairs which seems ok temperature wise. There is also an electric shower on the same floor as the boiler running off the cold water feed. Seems ok although flow seems a little lower. The boiler had inhibitor etc when it was installed.
Anything else I could check or is it back to the Yellow Pages and the wallet??
Many thanks in advance.
