have a problem with my baxi 105he . pressure goes down no leaks anywere.? dometic plated heat exchange . please help
hi yesb undonr prv at boiler no leeks. anywere gauge slightly bouncers about .and more wen hot tap onyes there is a leak the water is going somewhere!
have you checked the P.R.V. pipe
key board playing up. yes ive checked the prv pipe,no leeks. anywere.the gauge jumps about when htg on and more with hot tap on. then gradually loses its pressure. thankswhat, sorry didnt understand any of that..
hi thanks for reply just seen message. how would it get thruogh internall to the condensate,sounds knackerd dont it. thought it was something simple like dh heat exchange.could be internal leak and running away through the condensate pipe, turn boiler off, leave to cool down and check to see if any water is coming from the 22mm plastic pipe at the bottom of the boiler.
Rojaca if the pressure is dropping the pinhole won't be from the secondary dhw heat ex.....that would increase pressure and blow prv.....if the main is pinholed it will drip out the condense trap
