Baxi 105heselector switch reset circuit
14 Mar 2012
Manchester
could someone please explain the baxi reset switch circuit to me. stating what voltage to expect on main pcb A4 connector pins 5,2 & 1 for each sw position off, hw,heating,and reset.i am unfamiliar with this type of switch and have not been able to find a pin out or explanation in the manual. Many thanks for any help you can offer.
Thanks a lot for that :)
There is one query i have - you though 1 -B for reset the manual mentions:-
Check terminal I of ON/OFF/RESET selector is in
connection with PCB - A4 connector terminal 2
Check electrical continuity across terminals I & a of
ON/OFF/RESET selector when tumed to 'Reset' position
What do you think ?
It is difficult when i dont know the switch configuration - i was hoping to build up an appreciation using table view above.
Thanks Paul
if yes (to continuity) replace pcb
no idea what your trying to do with the table :wink:
you would be better off getting a switch and taking it apart.
