I have a Baxi 35/60 which will shut down frequently and the neons for both flame failure and safety thermostat activation flashing. On consulting the manual I measured a high resistance across the safety stat so I replaced it. Before replacing it I measured the new stat for resistance and it did read zero so I presumed this was correct and installed it into the boiler. The trouble is the boiler is still shutting down on the same faults and now there is a high resistance reading across the safety stat.
Not to get hung up on the resistance readings across the stat,Can somebody tell me if there is another possible answer to why the boiler is shutting down on these faults or did I buy a bogey safety stat.
Thanks in advance.
Thanks in advance.
