The thermistor I quoted temperature / resistance values for is the TDK B57891M0102+000 ( 1009 T/R curve )
Data sheet at
http://en.tdk.eu/inf/50/db/ntc_13/NTC_Leaded_disks_M891.pdf
The thermistors used in boiler temperature sensors are almost certainly going to be lower cost devices, most likely with a steeper T/R curve to simplify the electronics but at the cost of reduced accuracy in the temeperature measurement.
Data sheet at
Clearly information is erroneous as someone relying on what you post would automatically assume you are correct and end up changing components that may well be fine.
The point I am making, an I am surprised that I have to make it to "qualified engineers" is that the test has to verfy that not only is the themistor present and not open circuit but that it is still within specification ( and not the wrong type ).Bernard I'm not sure what point you're trying to make.
As to DP's method of testing a thermo couple temperature sensor...... Even Baxi provide a value for their temperature sensor at "cold" in the public domain information they produce.
Primary temperature sensor faulty.
Cold resistance approx. 11K ohms
(resistance reduces with increase in temp.)
s not only are you quoting wring value, you are also confused if you think thermocouple can provide resistances
Agreed. Copying and pasting from Google can be difficult at timesBut then we all make mistakes
