gas4you told you on the frirst post to....check the fan aps is activating and for any blockages in the fan venturi and aps pipes.liamcaswell said:hi baxpoti, is this a typical symptom of PCB failure? What makes you think it is not the APS??
Presumably you have done this?
the next thing to suspect is the PCB.
Yesliamcaswell said:From research, I've read that I need PCB: 5112380. Is this correct?
Venturis suffer from heat damage and APS pipes from condensation (had one on Friday)!
