Baxi 80E pilot won't light - No warnings
30 Dec 2006
The baxi boiler 80e, can't get the pilot light to ignite. have tried resetting, turning it off for awhile.
Pressure is ok, any tips - as its cold.
thanks
well i guess so , then if it doesn't - it doesn't give the noise to indicate the flame is going to ignite. so maybe you are right no pilot - but the result is the same - no heating, no flames..
the green light (power) - its an 80eeco, it only has 3 light on the front, and only the green is lit
MOD 2
please use the edit key ;)
is the reset inisde on the left along the first copper pipe, little brown button. that has two wires going to it?
i pressed it . a few times today already. but am not sure if this is the button.
it doesn't click or do anything, so i assume that it only pops out if there is a need for a reset?
If it works when you press the button........................
You have a serious overheating problem - if you 've reset a few times in one day
i pressed it a few times trying to fix it - its the only thing i remember the engineer doing last year, pressing a button inside boiler and it fixed it.
the fan is running and it makes the right sounds apart from the flame part.
do i have to press the reset button with the mains power off?
and how do i sort the pressure switch?
thanks for all the help, don't fancy spending nye getting a plumber
tried it all.
and still nothing. the button doesn't seem to need pressing as there is no click
:cry:
EDITED TO ADD
well time for sleep and boiler has decided to work, so any ideas what i should be looking to fix/ get fixed? as it only seems to cause problems when its cold. each winter. and it also looses pressure easy in the winter.
