I have a baxi back boiler, with a pump located near the boiler, and an immersion tank upstairs. Over the last year and half, whever the boiler shuts down (ie after it's run for a while and then shuts off, presumably due to thermostat saying it's hot enough now), I get a series of bangs. It started moderately quiet, and I was advised to run boiler silencer through the system. I've done this several times now, and the noise just keeps getting worse. At the moment the bangs have become startlingly loud, and actually rattles the fireplace.
The bangs are definitely coming from the boiler itself, not the tank or anything. They don't happen during operation, only once operation stops.
I've noticed the pump stops at the same time as the boiler, is that correct? If kettling is causing the bangs, I thought perhaps the pump should be continuing for a period after the boiler gas cuts out, so that the heat in the boiler can be dissipated rather than flash boiling a single section of water (I presume that flash boiling is the cause of the bangs, that's what every plumber I've spoken to has said is the cause).
I've drained and filled the system several times, and fully bled regularly.
Any thoughts anybody on what to do? I'm tempted to get a powerflush, but don't want to spend 400 quid and find it's just the same.... (as I say, I've run chemicals through so many times now it's not funny, can't believe there's much crap left in the system!).
Many thanks,
paul
Many thanks,
paul
