baxi back boiler
26 Nov 2005
Cheshire
radiators not getting hot. Pump works, but boiler only stays lit for 30 seconds at a time with stat and room stat on maximum
Probably run out of water. Check header tank, drain some water from a drain cock and monitor tank. Cold feed may be blocked. Air bleed valve by HW cylinder may need venting.
