Baxi Bermuda 552 Expansion pipe
10 Dec 2007
London
Hi since a new pump and 3 way valve was fitted there is a continuous flow out of the expansion pipe pump is set on position one. Any help would be appreciated
If the pipes are in the correct configuration ie, flow pipe from the boiler should have the exp pipe then the cold feed and lastly the pump as close as possible to the boiler then suspect a blockage in the cold feed exp pipe area.
Needs to cut out and replaced.
