System is:
Baxi Bermuda (13 yrs old)
Piping 30 years old
New Hot water tank
Magnaclean fitted
Spirovent fitted
3 way actuator fitted 2 years old
Grunfoss + pump 6 years old
Heating and Hot Water both work.
The pump appears to be OK, opened the screw on the front and there was vibration inside, and water coming out.
Am not OK with actuator's but both the H/W and C/H are working.
The noise is at the boiler. When it first fires up it is OK but as it starts to run longer it starts to bang. Probably about every 5 seconds until it switches off and then it will start the whole cycle again when it fires up
System is regularly serviced and the water coming out of the rads is clean (I have had the system emptied twice last year when fitting a magnaclean and spirovent), so methinks it probably isn't sludge in the system, but could be wrong.
Cannot think of any other info but would appreciate any pointers or indications of where to look.
Many thanks
Piping 30 years old
New Hot water tank
Magnaclean fitted
Spirovent fitted
Many thanks
