BAXI boiler problem
10 Jan 2008
Kent
Could you guys help me with this problem. I have a 10 year old BAXI boiler on a sealed system.
We went through a phase last winter where the boiler cut out and the overheat light came on a regular basis particularly when the weather was blustery outside. To get around this we had to reset the boiler and start it up every time it cut out. Eventually we contacted an engineer who replaced the fan.
This winter we have been having the same problem but now we are at the stage where we cannot fire up the boiler. The boiler on light comes on but the fan light does not and the pilot does not come on.
Could this be just a second faulty fan or could there be another underlying problem elsewhere? I am guessing here in terms of the location of the boiler which is in the loft and may be too exposed for the fan to cope. Is this likely?
Would your advice be to get another replacement fan and risk this happening on a regular basis or should I be thinking of a new boiler / relocation of the boiler / external protection to the flue? Your suggestions would be welcome.
Thanks for your help.
does the fan actually work or not, dont assume just because of the light
Hi Mick
Apart from the first boiler light comming on nothing else seems to happen. I can't hear the fan or anything else going.
Joe
If the fan is under 12 months old it should have some sort of warranty, get the same engineer back.
Does it look to you then that I have just been unlucky with my fans?!
you need to know if 240v to fan before condemning it
turn gas off just in case the fan kicks in and boiler tries lighting.
multimeter set to vac probes on live and neutral of fan, take great care as power has to be on and boiler calling for heat. If in doubt get a corgi in
