Baxi Combi 105 HE leak
21 Oct 2010
Cornwall
Got a leak just need some help in identifying the component and some advice on how hard to replace
[/img]
Dead simple. Turn off the water into the boiler and open the nearest hot tap to make safe. Part number 5111137 around £15 ish will have both bits you need to fix it. Change it as soon as possible before the microswictch gets damaged.
Thanks Beer lover, what do i need to change ? just the round outer plate behind that microswitch? and was it called?
It is just the gland that is leaking, undoes with a spanner. Fit only that bit if you want, but I always change the internal diaphragm at the same time - only an additional nut and six screws.
BTW turn off the power to the boiler before starting the repair.
Dead, dead easy, I promise :wink:
The P/no I gave you is the 'flow switch diaphragm service kit' The gland on the dhw flow switch is leaking
Brilliant thanks guys, just need to have power /boiler off and open hot tap to drain boiler?
Right got the spares today, now how do i discharge pressure in boiler?
why would you want to do that ?
your doing the hw side not the heating diaphragm.
just shut the mains stopcock and open the hot tap as said.
and cover the pcb with a cloth.
Just turn the power off and turn off all 3!!!
If your this bad with the water supply i feel a 10 page posting coming
Can anyone tell me where the o-ring goes and what way round also? I have taken the diaphragm casing apart carefully but have found no sign of one being there.
Many thanks
Ian
