Hi
Newbie here. Just wanting a bit of general advice in case I need to call a plumber out so that I don't get ripped off.
I have the above boiler which has been fitted in my house for about 5 years now. I have just put the heating on today and everything seemed to be working fine, then after about half an hour, the burner light went out on the boiler and it just stopped. Running a hot tap fires the burner back up and when I turn the hot tap off the burner stays on and the central heating starts to warm up for a bit....then the burner light goes out again.
Does anyone know what this may be? There are no indicator lamps flashing to give me any idea as to what the fault maybe. My missus fiddled about with the pressure and it was sitting at about 2.5 whilst it was fired up. I'm not sure how you can lower the pressure, if at all but wasn't sure if this might be the problem, although the manual states a normal operating temperature of between 1.0 and 2.0 but should not exceed 2.5 bar.
Any help would be greatly appreciated.
Thanks.
Thanks.
